Gauges and radio frustration
Old Jan 6, 2018 | 12:22 PM
JMichael17's Avatar
JMichael17 is on a distinguished road
Default Gauges and radio frustration
Every once in a while my gauges and radio will stop working while the car is on I’m trying to figure out why.
01 blazer 4 door 4wd lt
Old Jan 6, 2018 | 12:51 PM
I once had my gauges and radio go out (along with the HVAC) when the radio shorted out blowing a fuse. Maybe there is an intermittent open circuit in that circuit or at the supply voltage for that circuit that serves all those components?
Old Jan 6, 2018 | 01:03 PM
Rusty Nuts's Avatar
Welcome to the forum. Is the stereo stock? If it's aftermarket the first thing I check is the previous installer's wiring. Do all the gauges drop out or just the speedometer?
Old Jan 6, 2018 | 01:04 PM
JMichael17's Avatar
All I know is that a swift hit to the dash turns everything back on. I’m thinking a loose ground wire?
Old Jan 6, 2018 | 01:16 PM
JMichael17's Avatar
The radio is aftermarket. I put it in. all the connections were soldered. All my gauges lose power and the gear selector lights turn off but my airbag light that is originally on stays on
Old Jan 6, 2018 | 01:27 PM
Rusty Nuts's Avatar
The factory stereo had SCV (speed compensated volume) most aftermarket models don't. If that wire is not capped off it grounds out and makes the speedometer drop out until the dash gets smacked. Sounds like you're on the right track investigating grounds.
Old Jan 6, 2018 | 01:29 PM
JMichael17's Avatar
Ok would you happen to know which wire that would be in the harness because when I installed the radio I didn’t chop the stock radio harness up I got a stock to aftermarket adapter. And would the scv wire grounding out cause me to lose all my gauges or just the speedometer ?
Old Jan 6, 2018 | 01:32 PM
Rusty Nuts's Avatar
The times I've seen it only took out the speedo. Was there a problem with the instrument cluster before the stereo upgrade?
Old Jan 6, 2018 | 01:35 PM
JMichael17's Avatar
I’m am not entirely sure. I had to replace the stock radio because who ever had it before me spilled something down the dash and all the buttons on the stock radio were stuck
Old Jan 6, 2018 | 01:36 PM
Rusty Nuts's Avatar
When I quote my 2000 factory service manual for wiring on a different year I'm proven wrong. I'd search 01 specifically.
