head lights isuue
Old Oct 9, 2013 | 06:00 PM
jatkins3983's Avatar
jatkins3983 is on a distinguished road
Default head lights isuue
I got this odd thing going on with my headlights. Even when the light switch is set to only the running lights the head lights come on too. The switch does nothing I can't change it from DRL to headlights at all. The only time I can turn it on and the headlights don't come on is when I crank it up with the E brake engaged. As soon as I let off the E brake the headlights come on
Old Oct 9, 2013 | 06:17 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
the daylight switch is most likely the problem. its the little button looking thing located at the right front dash speaker
Old Oct 9, 2013 | 06:22 PM
I will give that a look but truth be told I don't know if it has that I'm curious if there is coorision on the selector for the lights. Its a dial with 3 options on it
Old Oct 9, 2013 | 07:54 PM
warthogdriver's Avatar
thats your DRL lights. look up DRL delete if you want them off.
they come on when in gear...then the AHL (auto head lights ) will kick in at night. the AHL sensor is on the pass side under the dash speaker grille...that can be disabled as well.
Old Oct 9, 2013 | 09:11 PM
But if the ahl sensor is bad wouldn't that automatically turn the headlights on as if it were dark out and override the DRL?
Old Oct 10, 2013 | 05:43 PM
OK cool wish I could figure out why the AHL is on all day at any time
Old Oct 15, 2013 | 11:48 AM
swells87's Avatar
swells87 is on a distinguished road
I have this same problem, my headlights are on all the time. Do I just need to replace that sensor in the speaker cover? The interesting part is that the dash lights turn on when it is dark but the head lights are always on when the truck is running. Is this normal?
Old Oct 15, 2013 | 01:45 PM
Blazer 98's Avatar
Blazer 98 is on a distinguished road
Yes, I canceled the drls so they weren't on all the time.
Old Oct 15, 2013 | 01:48 PM
swells87's Avatar
when you canceled the DRL's does it effect the AHL's at all, I like the auto head lights, just dont need them on all day, only when its dark out. How did you cancel the drl's?
Old Oct 15, 2013 | 08:52 PM
Blazer 98's Avatar
The AHL works like normal, I took the drl relay in the engine compartment, and bent one of the tabs. I am not sure what one it was. I know different years have different ways to cancel the DRLs.
echo1
15
Aug 28, 2012 07:56 PM
mrspeedy69
May 23, 2012 09:11 AM
J.R. Clay
Mar 17, 2011 08:22 PM
ewingmh
May 13, 2007 07:21 AM
98BlackBlazer
Aug 28, 2006 01:31 AM
