headlamp flickering
Old Dec 28, 2011 | 09:15 PM
blazernz's Avatar
blazernz is on a distinguished road
Exclamation headlamp flickering
I have one headlamp that is flickering. Have take both units out and tried them in each headlight. Same problem. I have a alternator that is screaming like anything. Could this be the problem?
Old Dec 28, 2011 | 09:43 PM
xgiovannix12's Avatar
yup a bad alternator could cause that
it might not be charging the system correctly
Old Dec 28, 2011 | 10:06 PM
blazernz's Avatar
I put the wrong thing in, I meant to say relay not alternator. The relay is screaming
Old Dec 28, 2011 | 10:10 PM
what relay are you talking about ?
also it would help to tell us what your driving
Pics are great also
Old Dec 28, 2011 | 10:52 PM
blazernz's Avatar
blazer 2002, right hand drive.
there are two relays at the back by the wiper hosing for the headlights. When you put the lights on full beam, it screams like hell. Only one headlight was flickering.
Last edited by swartlkk; Dec 29, 2011 at 06:56 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 28, 2011 | 11:25 PM
Rottidog's Avatar
Relay has an issue (though I'm unfamiliar with relays on a firewall). But either could be a ground issue. Does the flickering happen more over bumps or when the engine is reved? If so that sounds like a ground or a connection issue. See what could move as the engine turns as it gets reved. The engine ground at the rear to the firewall (PS LHD vehicles). Might even be as simple as a bad connection in that connection housing. You said you swapped headlights & the same side has the same issue so - what about the connections? Tough to test them, this side of replacing them (not a big coin issue really) but it's the same issue with that side, we know that - right?!
Use that thinking to narrow down the possibilities. <--- whats specific with THIS side.
Just my thoughts, connection issues, be it a ground - maybe or a molex/head light connection issue. Worse case scenerio is a bad BCM IMO - $40 at a wrecker.
Check the grounds just because & look for water, corrosion in the connector to the troublesom light. If not that trace it back.
Old Dec 29, 2011 | 12:27 PM
Thogert's Avatar
I learned something today. I didn't know relays could scream.
DaveHearne
Oct 20, 2012 02:46 PM
68dartboy
Nov 6, 2011 05:44 AM
toobatheviking
May 26, 2011 11:54 AM
mross45640
May 17, 2011 10:24 AM
Indo G
Dec 4, 2008 10:40 AM
