headlights are dim! 1985 blazer
Old Feb 10, 2015 | 10:02 AM
Edvalle10's Avatar
Edvalle10 is on a distinguished road
Default headlights are dim! 1985 blazer
My low beams are extremely dim. And the high beams are dim as well but still light up as much as some low beams normally would. What might be causing this?
Old Feb 10, 2015 | 10:04 AM
BirchyBoy's Avatar
BirchyBoy is on a distinguished road
Is your battery staying charged? It could be a low alternator output.
Old Feb 11, 2015 | 01:20 PM
Edvalle10's Avatar
Yea i just got a new battery not too long ago...
Old Feb 11, 2015 | 05:08 PM
Bad headlamp ground. Could be bad sockets, or a poor connection at the body. Follow the wires from the lamps. They ground to the radiator support, one on each side of the vehicle. Usually attached to a rusted out stud with a nut. Take them apart, shine them up, put them back together.
Old Feb 12, 2015 | 08:15 AM
Edvalle10's Avatar
Cool man thanks! Ill be checking that out later today!!!. Ill let u know if it works.
Old Feb 12, 2015 | 09:59 AM
If the grounds are good, I would go back to the question below:
A new battery doesn't mean that the alternator is properly maintaining system voltage at the appropriate 13.5-14.5 volts. Low system voltage will definitely impact headlight brightness. Use a multimeter to display system voltage with the engine running.
Dieseldog95
Nov 10, 2010 07:10 PM
NUM-1-GM-FAN
Apr 22, 2010 08:04 PM
aspenchevy
Nov 10, 2008 08:28 PM
phil01ss
May 29, 2006 09:21 AM
jaleg
Nov 17, 2004 02:53 PM
