Headlights flash when I drive...
Old Sep 20, 2013 | 11:51 AM
Piero's Avatar
Piero is on a distinguished road
Default Headlights flash when I drive...
There's a problem on my 95 Blazer 4x4. When I drive by night, when I put the hi-beams, they start to flash after 10 minutes... If I stay in low beams there is no problem.
When it flashes I can hear a relay on the right, and I see a blue light on the cluster.
Anybody knows what's the problem ?
Old Sep 20, 2013 | 01:11 PM
spittybays
Guest
Posts: n/a
When they start to flash if pull the multi function switch to the high beam flash position and hold it will they stop flashing?
Old Sep 20, 2013 | 02:58 PM
Piero's Avatar
I don't remember !
But when I try to switch several times, the low beam flashes too.... But it's random...
Oh I forgot to say my multifunction switch is new !
Old Sep 20, 2013 | 07:54 PM
spittybays
Guest
Posts: n/a
Ah oui! Multi-function, why did you replace in the first place?
Old Sep 21, 2013 | 05:39 AM
Piero's Avatar
I've replaced the multifunction because brake lights didn't work.
Old Sep 22, 2013 | 03:39 PM
Piero's Avatar
Maybe the relay overheats ?
Old Sep 22, 2013 | 04:41 PM
spittybays
Guest
Posts: n/a
Not positive your 95 has a headlamp relay. Does anyone else know? I think its wired straight through the multi-function but not sure.
Old Sep 22, 2013 | 05:46 PM
burned's Avatar
burned is on a distinguished road
No relay. Only for DRl and fog lamps.
I would suggest check wiring.
The Light green wire is the power for your high beams. It is shared by both lights.
Oh almost forgot, the headlight switch can also do this.
Old Sep 22, 2013 | 05:47 PM
richphotos's Avatar
*moved to lighting and electrical*
Old Sep 23, 2013 | 05:20 AM
Piero's Avatar
Thanks for the video ! I'll check my switch...
Question : What's a DRI ?
