Heater fan problem after replacing the heater core
Old Feb 9, 2021 | 04:52 PM
johnnya's Avatar
johnnya is on a distinguished road
Default Heater fan problem after replacing the heater core
I recently replaced the heater core and everything seems to work except the heater fan
This is on a 1995 Blazer 4 door, 4WD
Any suggestions?
Old Feb 9, 2021 | 05:05 PM
johnnya's Avatar
Sorry.
Old Feb 9, 2021 | 08:40 PM
I would suggest start looking at the HVAC control wiring and plugs, as the blow motor fan is actually under the hood so there's not much you could have done with it, unless you unplugged the motor or resistor when getting the evap box bolts out (if you took it out that is, most don't bother pulling it completely out...)
Old Feb 9, 2021 | 09:28 PM
johnnya's Avatar
Thanks for the reply, I have checked the connections on the back of the heater/AC panel. I think they're good.
I searched for the location of the fan relay, and learned it's one of the relays that are at the rear of the engine compartment near the heater hose connections>
I'm hoping I jostled a wire/connection while re-connecting the heater hoses.
I'll check that tomorrow.
Old Feb 15, 2021 | 12:14 PM
johnnya's Avatar
I found that the orange wire has no power with the heater selected and the fan speed selected to high.
RedValor
Oct 9, 2021 05:43 PM
00blzrs10
Dec 3, 2010 10:11 AM
ramairmustang
Mar 8, 2010 04:03 AM
dphill2006
Nov 1, 2009 04:44 PM
KdogTN
Sep 28, 2008 05:18 PM
