help
just bought 2000 blazer 4x4 146k miles.fuel pump went out and replaced,no problem.the wipers only worked on hi speed and horn didnt work.took it back and guy replaced the wiper circuit board and wiper control.he also removed the airbag and replaced the horn assembly,he said someond had replaced the ignition switch so the steering wheele wont lock,i dont care about that.everything works fine now but the air bag light blinks when i start the motor and stays on.any help on what i should look for.thanks
Originally Posted by mep60
(Post 393830)
I did it a long time ago with my GMC and it worked. I will search the internet to try to find the answer, you might find it before I do. Mike |
