Help!!! Electrical problems!!!!!
Old Dec 1, 2013 | 07:55 PM
Masonslaton's Avatar
Masonslaton is on a distinguished road
Default Help!!! Electrical problems!!!!!
Hey guys, I have a 98 blazer 4x4 and have recently had some electrical problems.... My truck started having trouble starting about two weeks ago, I went to autozone and they said I needed a new alternator, got the alternator, replaced it and my car was no different, still needed a jump to get it started. I then replaced my battery and my car ran fine all day, until now. I went to start it, and everything seemed to have power, only it would not start, my power locks also went out and intermittently would switch on their own. I have since pulled the fuse to the locks to avoid that becoming a further problem, all wires leading to my battery, alternator and starter are clean and undamaged.
Any ideas what this could be or how I could diagnose the problem?
Old Dec 2, 2013 | 11:12 AM
hans109h's Avatar
hans109h is on a distinguished road
I suspect that you may have a poor ground connection. On my 98 the ground attached to the frame underneath the metal plate that the battery sits on was bad. I replaced the ground cable and my (similar) problems went away. It's easy to diagnose, but probably just as easy to inspect.
Hans
Old Dec 12, 2013 | 07:04 AM
jimspahr@msn.com's Avatar
Hans, are you saying that ground is underneath the battery tray , so to get to it , you need to remove the battery and the batt. tray? Or can you access it from under the vehicle?
Old Dec 13, 2013 | 10:52 AM
hans109h's Avatar
It's been a while, but I believe to get to the ground attached to the front of the frame you have to remove the batter and tray, and then it's in a plastic housing. I'm not sure you could get to this from underneath unless you removed the shroud.
Just pop out the battery.
Old Dec 14, 2013 | 08:42 AM
Hans, thanks for the good info. It helps with my projects to have this type of info. I like GM. but why does GM put some of the critical 'grounds' and electrical connections under a battery tray? Then the connections and grounds corrode and there goes the electrical integrity. And why does the battery leak? Because of the side terminal batteries that GM prefers. Tip: don't over tighten the battery terminals.
bobby099
Apr 16, 2013 06:19 PM
JoSHN
Sep 14, 2012 04:56 PM
upblazer95
Apr 4, 2009 08:27 PM
chris24301
Jan 24, 2007 11:01 AM
joe
Apr 19, 2006 05:33 PM
