help with hazard lights
Old Sep 2, 2011 | 03:24 PM
chilecol's Avatar
chilecol is on a distinguished road
Default help with hazard lights
my 95 blazer has a strange problem. with the hazard button in the off or raised position my turn signal and brake lights dont work except for the chms led strip which does. with the button depressed the brake and turn signal lights work normally but the hazard lights dont work at all. is it the relay? or has a previous owner played with the wiring? HELP
Old Sep 2, 2011 | 05:22 PM
janddcunningham's Avatar
janddcunningham is on a distinguished road
Ha, you need a new multifunction switch or possibly just the hazard switch needs replaced. I could wiggle mine to the left and i would have break lights so i wedged a piece of card board to hold it and i have lights but sooner or later i will have to replace my turn sig. Switch.
Old Sep 2, 2011 | 05:28 PM
xgiovannix12's Avatar
I agree play around with the hazzard switch Push it slightly or pull it slightly and see if your lights start working correctly
On my brothers 2nd gen i had to shim something into the hazard switch to get home with out being pulled over
Old Sep 2, 2011 | 05:48 PM
aneill75's Avatar
aneill75 is on a distinguished road
Been there..... Had a 96 S10. Broke the switch - Dealer wanted $400 just for the switch. Had a carpenters pencil wedged in the dash for 2 years before buying a COMPLETE column at a swap meet for $20
Or, possibly the hazard flasher
Aaron
Old Sep 2, 2011 | 05:59 PM
pettyfog's Avatar
Shim it so it works okay.
Sadly there's no replacement haz sw only for that year.. only 98 to early 00'
Check ebay/rockauto.. I dont recommend Wells/airtex
radiorara
Apr 14, 2011 03:04 PM
fbobak
Mar 1, 2011 12:20 PM
dundeeboy
Nov 9, 2010 05:54 PM
TonyOneX
Apr 14, 2007 12:34 AM
rryker
Apr 25, 2006 04:14 PM
