Hey y'all new to Blazer's (not 4x4s), could definitely use some guidance(electrical s
Old Oct 29, 2018 | 05:37 PM
I would suggest pulling the alternator off and having it tested. I know Advance Auto Parts can bench test them, I'm sure most all parts stores can. I wander if the alternator catastrophicly failed causing the grinding noise, then at the same time the regular in it failed and sent a voltage spike through the electrical system and knocked out the PCM... Would suck to replace the PCM only to have a fresh one fry as soon as you started the truck because the alternator spiked the voltage again...
Just a thought
Old Oct 29, 2018 | 05:44 PM
Catecean Damnation's Avatar
Catecean Damnation is on a distinguished road
That's good advice, my buddy suggested the same, so I tried that. The alternator is fine, so I'm not sure what else to do. Any other ideas?
Old Oct 30, 2018 | 01:05 PM
Rusty Nuts's Avatar
I make sure all my grounds are less than 5 ohms to chassis ground before I spend money on electrical parts. I'm wondering if you lost an engine to chassis or pcm ground that could throw all those codes and not blow a fuse. Maybe someone knows what voltage signal causes those individual codes and combined they could point us toward the problem.
Old Oct 30, 2018 | 08:27 PM
Big'n's Avatar
Big'n is on a distinguished road
If you find out it's a bad pcm. Google flag ship one.com just gone a pcm from them a month ago just send them your vin an 88 bucks an they send you a plug n play unit life time warranty
Old Oct 31, 2018 | 08:48 AM
LesMyer's Avatar
Originally Posted by Catecean Damnation
So, as best I can figure, all the involved codes come off of systems routed through the PCM, and the fuses and relays seem fine... I'm beginning to think that the PCM is toast. And yes the codes come back after being cleared.
I am thinking so too! But did something cause it to fail? Probably a try and see. You can get used PCM through Internet that is programmed to your VIN. They typically offer a return policy that would only cost you maybe $20 + ship to find out.
johnnylovsey
Apr 3, 2015 06:41 PM
95vortec4.3
Aug 16, 2013 06:57 AM
ABSLT
Jan 24, 2011 11:03 AM
tim68
Jan 23, 2011 08:12 PM
Takz
Feb 17, 2010 05:16 PM
