Hi beam problem
Old Feb 23, 2012 | 02:58 PM
finity's Avatar
finity is on a distinguished road
Default Hi beam problem
Does anyone have a good (better than the "typical" diagram in the haynes manual) wiring diagram of the Headlight circuit with DRL's but no fog lights?
When I turn on the hi-beams the hi-beam indicator turns on but the headlights turn off (i.e. no hi-beams). Since the hi-beam indicator turns on I know that the DRL is getting voltage from the dimmer switch so I'm pretty sure that the dimmer switch is good.
Is there anything else in the circuit between the dimmer switch & the hi beam lamps? It doesn't show anything in the haynes manual drawing.
Mike4x4ing
Jul 6, 2013 01:21 PM
dkatz
Mar 2, 2011 06:44 AM
norcalBlaze
Feb 25, 2011 09:23 PM
marine
Jan 28, 2010 07:05 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
