hi-mount brake light in-op
Hey All,
Noticed that my LED brake light array at the top of the rear hatch, does not light up when brakes are applied. Where should I start my troubleshooting? I'd be surprised if that were on it's own fuse/circuit. Thanks! |
I have has a couple fail over the years. The first was due to a bad seal on the lens from the factory letting moisture in and corroding the circuit board. The second was the wire breaking just on the outside of the grommet where it comes through the rear window. the break in the wire was not noticeable because of the outer shielding, but the wire was unusually flexible in that one spot.
Originally Posted by Diaita
(Post 555279)
Will pull that apart and see what it looks like inside I guess. Thanks for sharing your findings on the various failures. |
