which hid kit is best?
#61
I plugged in the low beam lights pretty simple just plug in and they dont work. any advice?
#62
ok everythings plugged in high and low beam and still nothing. Its a 35 watt for both high and low 6000k.
#63
you try plugging them in both ways? some are reverse for some reason
#64
You mean like lows in highs and vice versa?
#65
Nevermind i reversed the polarity and they look great. thanks for all the help.
#66
the high beams i just did so they match, the lighting is kinda weird from them.
most of the kits i install at work i also have to reverse too just on a side note, unless you skip the HID bulbs extension for the factory bulb to make it to the ballast. and just plug the truck socket into the ballast itself then youre usually fine. the extension isnt needed unless you have a sealed lens with the bulbs inside, like a dodge truck, lol and then you cut a hole in the cover and put that rubber plug in, then no water and the light doesnt fog up... even projectors with HIDs in them
#67
I don't know about the rest of you guys, but I am getting tired of recieving the same lame backorder email from DDM which after I called them isn't even true as far as time frame goes. Quick yanking my dick, DDM.
#68
Finally got my HID's today. Straight from xinghua city china...lol WTF
#69
god i hope u dont get a bad ballast or something... i bet it costs an arm and a leg to ship electronics that far!
#70
The bulb boxes have the same part # and say 9005/6 on them. What's up with that? Jim
