high mount rear brake light removal from glass
Old Jan 19, 2011 | 04:00 AM
neex's Avatar
neex is on a distinguished road
Default high mount rear brake light removal from glass
Hi there,
Although there have been lots of great threads talking about reviving the third brake light, troubleshooting it, etc., I cannot remove mine. I've tried many times and no go. It's off a 95 and it is mounted to the rear glass. What is the trick? I've tried to slip something under it while turning the screwdriver to see if I can isolate a nut that might be spinning. If I drill off the heads of the screws will it come right off? I've been close to just replacing the rear glass with one that works from the wreckers to avoid this frustration but it seems a little excessive...
Arrrrgh.
Thank you,
Andrew.
Old Jan 22, 2011 | 04:43 PM
neex's Avatar
Has nobody else seriously had a problem removing this 3rd brake light off the hatch glass? Maybe I'm screwed...
Thanks!
A.
Old Jan 22, 2011 | 05:55 PM
cochran07's Avatar
cochran07 is an unknown quantity at this point
Miines already broken. One side of the plastic mounting underneigth the light itself has snapped so mine is just chilling. I probably need to fix that its just not that big of a deal to me. If all else fails maybe remove the back glass?
Old Jan 22, 2011 | 08:36 PM
old skool luvr's Avatar
don't know, mine is body mounted.
but i do have a window in the garage that has a 3rd BL on it. if i have time in the morning, i'll take a quick look @ it, see if i can see what is giving you guys so much issue.
Old Jan 22, 2011 | 08:46 PM
cochran07's Avatar
Mines not bugging me. Ill get around to it eventually but not top priority. But to know of any future snags will be nice!
Old Jan 25, 2011 | 12:06 AM
neex's Avatar
Fantastic! Thank you. This thing has been a bit of a Bermuda Triangle for me to figure out. I'm sure it's botched and needs replacing (if only I could remove it).... I'm wondering if hammering it underneath with a gasket scraper might do it. Maybe I should smash the hatch with a hammer.... lol.
A.
Old Jan 25, 2011 | 12:27 AM
cochran07's Avatar
I forgot about this. Dang I meant to look at mine and see for ya since one side is broke anyways. Maybe Ill remember in the morning to check it out.
Old Jan 31, 2011 | 09:01 PM
neex's Avatar
no worries - if you figure it out let me know.
Thanks,
A.
Old Jan 31, 2011 | 11:08 PM
s**t! i forgot all about this as well.
i'll see if i can get @ that window in my garage tomorrow. see if i can figure out how that 3rd BLcomes off.
Old Feb 1, 2011 | 04:20 AM
cochran07's Avatar
Alright I took a peaksie at mine the other day but completly forgot to say anything about it. It looks like the plastic on the hatch itself has a slot manufactured in for the nut, then the nut sits in there and the actual light bolts down. If I could post pics I would but I can't. Mine is broke right there so I can move the light around to see. Neex pm your email address and I can email you a picture of what I'm talking about so you can understand a little better. But I'm willing to bet you've stripped the plastic where the nut acutally is "held in" at.
