Horn wiring question?
Old Sep 5, 2012 | 04:27 PM
jaystoy's Avatar
jaystoy is on a distinguished road
Default Horn wiring question?
Need to be pointed in the right direction. 94 s10 blazer. While replacing the steering wheel, I busted/snapped the plastic piece on the column that hold the spring loaded wire for the horn. Now no horn. I bought one of the napa horn button to wire in and mount on the steering wheel. What is the best way to wire this? It came with no directions. Where do I grab or what color is the horn lead to bring to the switch?
Old Sep 6, 2012 | 09:59 PM
MyHeadache's Avatar
MyHeadache is on a distinguished road
Wouldn't recommend mounting to steering wheel.
Mount it on the under side of the dash out of the way of you knees.
The way that the original horn works. When you press the horn pad on the steering wheel. The wire you broke makes contact with ground. That completes the ground needed for the horn relay to kick in and send 12v+ from the horn relay to the horn. Not the horn pad on the steering wheel to the horn.
If you can trace the wire that is broken down through the steering column and find it under the dash at the base of the steering column.
Connect that wire to the button from NAPA.
Connect a ground to the other side of the button.
When you press button the horn should work.
speedhead
Mar 16, 2012 06:54 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
raptorman
19
Jan 14, 2010 10:21 PM
Blazin1
Jan 16, 2009 08:23 PM
clutch
15
Jan 5, 2007 02:58 AM
