How to adjust 2nd Gen. headlights !
Old Dec 1, 2021 | 11:56 AM
jimspahr@msn.com's Avatar
Default How to adjust 2nd Gen. headlights !
i needed to adjust my new replacement 2003 Headlights from 1A Auto. I could find the SXS on how many feet from a vertical , flat surface= 25 ft. , but not the CW vs CCW to adjust up or down. The middle screw in each side of the H/L assembly is for up or down adjustment. The screw on the outside of each headlight is for left or right adjustment. Both of the 'adjusting screws' are an External Torx or E Torx and the center of the screw is a small Phillips screwdriver. To adjust the H/L up= turn the middle screw Clockwise. To adjust the H/L down =turn the screw CCW. The left or right adjustment screw is on the outside of each H/L assembly and you go in through the top radiator support and go straight down. E Torx sockets are not a common tool, so I used a 6 mm socket with a short=2" to 4" extension.
TheSaint
Aug 28, 2016 08:11 AM
richphotos
Sep 3, 2013 11:31 PM
davtak
Jan 28, 2012 05:13 PM
Crestwood1001
May 31, 2009 10:45 PM
psawatsky
Aug 6, 2005 01:48 AM
