how do you align too low headlights?
Old Jul 29, 2015 | 06:46 PM
puttster's Avatar
Default how do you align too low headlights?
I fixed my headlights (pointing too high, see fix below) but now they point too low. I see a torx screw just above them, flanked by two hex screws. Is the torx the adjuster?
Puttster
"On my new to me 2002 Blazer it seemed the headlights were too high. I wanted to align them before going in for inspection. I found this forum and everything I needed to fix the problem. It was all very satisfying!
PO had replaced bulbs but did not insert the lower tabs of the headlight assembly into their slots. So, following instructions found here, I unsnapped the grill (held on by clips only) and I could see where the tabs were not in their slots. On the frame behind the lights (in front of the battery) are two vertical tabs about 6" long. To remove the assembly, pull them up and it falls out. To reinstall, put it back, with the lower tabs in their slots, replace the 6" tabs, line up the clips on the grill and push it back into place. DONE! "
Old Aug 1, 2015 | 08:29 PM
benjusa's Avatar
benjusa is on a distinguished road
The Torx screw is the one you want to use to adjust your headlights. There should be one for up and down and one for left and right.
Old Nov 14, 2015 | 08:50 PM
pmanwarren2015's Avatar
pmanwarren2015 is on a distinguished road
what if the place where you put the clips are gone can it still be fixed ?
Old Nov 17, 2015 | 07:37 AM
puttster's Avatar
The clips that hold the grill on?
Old Nov 17, 2015 | 08:07 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
I`m not sure,but I would help you if I could,i`ve never had to worry about this not just yet.
cferry7
Oct 15, 2013 03:19 PM
patterrr
Apr 2, 2011 10:09 AM
blzn95
Jan 14, 2009 09:20 AM
DerCribben
Nov 15, 2007 06:41 PM
DSBenson
17
Apr 29, 2007 04:54 PM
