Ignition Module...
Old Oct 18, 2012 | 10:17 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Arrow CaptainHook is correct
The 98 C1500 engine is the same as your 97 bravada.Theres noway a throttlebody would even start cause your pcm or computer wouldnt recognise that engine.I would say you have other problems other than an ignition coil or module.Another thing is a throttle body manifold will not fit on a 96 block or newer.The heads and manifold bolt pattern are completely different and wont match.The wiring harness would not match to a TBI engine either.
Old Oct 19, 2012 | 09:07 AM
bravada97nc's Avatar
bravada97nc is on a distinguished road
Okay, well I am glad that I know I dont have a throttle body cause I have been telling people I did, thats what someone told me it was... no wonder I cant get any help with it when I dont know what I've got!! Yes that is exactly how it looks Captain Hook, to the tee. But the motor that came out looked significantly different as far as the intake manifold goes, wish I had a picture. It did not have that black plastic part in the middle that reminds me of a traditional 'old style' carb.
Old Oct 19, 2012 | 09:11 AM
Since this thread isnt really about an Ignition Module anymore should I close it and post somewhere else? Just wondering, I have seen where someone was told they had posted in the wrong section before.
Old Oct 19, 2012 | 10:53 AM
Default I wish that you had a pic also
Cause both engines should be indentical.
Old Oct 20, 2012 | 08:46 AM
Did the engine that came out look similar to this:
Old Oct 24, 2012 | 08:22 PM
Thank you Capn Hook for all your help and espec for straightening me out about the type of intake I have, made me feel pretty silly to be honest! I can now get the truck to run but it still has a misfire and no power, so I am taking it to get a diagnostic test done sometime soon. The wife wants to sell it (it was her vehicle primarily) but I hope to get this kink ironed out first so I can get a lil more out of it hopefully. Thanks again!
Old Oct 24, 2012 | 08:24 PM
And also, I LOVE THE 'Our Shovels Are Ready' pic - I just hope it HAPPENS!!
Old Oct 25, 2012 | 01:57 AM
spunnkee's Avatar
spunnkee is on a distinguished road
maybe not, the module is an electrical part.take it back and have them trade you out.
reset your plugs @.035, take the coil wire off at the coil,
turn it over checking for spark.
'got spark, put wire back,
turn the key on for 15 seconds with out cranking
3 or 4 times in a row
and try starting it again.
if it won't start,
check the air gap on the crank angle sensor.
Old Oct 25, 2012 | 02:08 PM
Originally Posted by spunnkee
....reset your plugs @.035 ....check the air gap on the crank angle sensor.
Plug gap set at .035" isn't near large enough to burn the fuel efficiently, and the plugs will fuel foul. Plug gap for CSFI engines is .060"
The crankshaft position sensor is not adjustable. If it's disturbed in any way, the crankshaft position sensor relearn procedure is necessary. If there's a problem with the sensor, a DTC will be set.
Brian5792
Oct 24, 2018 11:34 AM
Terryh1968
Feb 14, 2008 09:06 PM
USMaverick101
Oct 31, 2006 03:10 AM
USMaverick101
Oct 29, 2006 10:29 AM
jerickso
Apr 20, 2006 11:05 PM
