Removing 194 bulbs from dash cluster gauges???
Old Oct 24, 2012 | 02:22 PM
420Blazin4X4's Avatar
420Blazin4X4 is on a distinguished road
Default Removing 194 bulbs from dash cluster gauges???
Im trying to remove the bulbs from the little twist housings from my gauge cluster...Anyone know how to go about doing this without busting the things? Appreciate any help...
Old Oct 24, 2012 | 03:53 PM
Thogert's Avatar
They are soldered into the twist lock bases. You will need to find new ones either at your local parts shop, or a junkyard. You can also buy them from superbrightleds.com
Old Oct 24, 2012 | 05:35 PM
I was hoping you would be the one to answer..lol figured you would know my dilemma.. Well I was able to get one bulb out I used a scalpel blade to separate the soldered wire from the little tabs...I bought leds from a guy on ebay...They are pretty much the type I seen someone had for sale on the forum here in the classifieds a bit ago..I played hell getting the wires into the little slots..But it just seems that the LED unit doesn't hold into the twist lock bases all that great..Is there anything I can use to get them to stay in there...possibly a little dot of lock-tite..I know that stuff seems to be pretty heat resistant..I am going to solder the connections..I just dont want to have the LED fall out when I put my dash back together..Or do you have any suggestions on what will hold the LED`s in good? The LED`s I got are the 5 SMD wide angle wedges...only difference from superbriteleds site is these have blue base casings... Appreciate it Thogert..
Old Oct 25, 2012 | 01:47 AM
Thogert's Avatar
You don't need to worry about heat from those leds, at the base anyway. You can use any kind of glue/ epoxy as long as you don't bridge the contacts with anything conductive.
Old Oct 25, 2012 | 03:37 PM
Sweet ty ...much appreciated man...my next task is to get all the rest of the leds I need to do the doors and the rest of the dash..Thanks so much for your list again...
Old Oct 26, 2012 | 01:36 AM
Thogert's Avatar
Yeah, no problem, it's what I'm here for.
jayj99jimmy
Dec 20, 2011 11:27 AM
raider62
Sep 27, 2011 07:56 AM
blazinloud
Nov 6, 2010 06:03 PM
luiguiv
Jul 30, 2010 08:58 AM
frostblazer
Jun 15, 2010 10:25 PM
