Instrument Cluster Help.
Hey guys, I have a 1997 Blazer with a floor shift. I have a 1996 parts truck with a column shift but the instrument cluster has a tach. What i was wondering is if you can change the two out without any problems. Thanks.
I'm a little confused on what you are asking. I know the title says instrument cluster help but then you mentioned a floor shift and column shift. If you are talking strictly the instrument clusters, 1995-1997 instrument clusters are interchangeable. I used to have a tachless instrument cluster but then installed one with a tach. I like seeing the rpm's. It was all plug n play if you are wondering. The install sucked because the column shifter got in the way and you had to remove a few things to get access to the cluster, but not bad. Wish I had a floor shifter.
Sweet, i just needed to know that it would work. but What I meant is my blazer has a floor shift in it and the one I want to put in is a column shift with the shift indicator in the cluster.
BlazerGuy2001
16
Feb 9, 2026 02:54 PM
error_401
Mar 17, 2008 06:39 PM
DoubleSprings
Sep 15, 2007 11:20 PM
Russ57
May 14, 2007 01:43 AM
