Keep blowing trailer running lights fuse. Why?
Old Sep 19, 2011 | 10:32 PM
Hank3band's Avatar
Hank3band is on a distinguished road
Default Keep blowing trailer running lights fuse. Why?
I just bought a new 6x12 enclosed trailer with LED tail lights and I can't keep the Blazer from blowing the 10amp fuse under the hood for the trailer parking/running lights. More specifically, the fuse will blow after having both the brakes pressed and a turn signal on. I drove over 200 miles with just the parking lights on without blowing the fuse but when I stopped and turned on the signal, it pops.
Any ideas? Bad ground connection? Short?
Where is a good place to start?
PS- Here is a pic of the trailer.
Old Sep 19, 2011 | 11:38 PM
xgiovannix12's Avatar
A short can cause a fuse to pop you might have a short in the trailer plug its self id start checking the wires
know any 1 with a trailer ? try the lights on there trailer see if the fuse blows
fuse might be weak too but id check for shorts 1st
Old Sep 20, 2011 | 08:38 AM
Hank3band's Avatar
Thanks for the reply. Trailer is new. It blew 10 and 15 amp fuse. Where is a good place to start looking for the short?
Old Sep 20, 2011 | 09:08 AM
like i said i would try on a different trailer if it dont blow your trailer might be the problem if it dose i start checking the trailer plug on the truck
p90tr8
Mar 18, 2014 05:56 PM
01blueblaze
Oct 16, 2010 01:39 PM
Concerned
Apr 1, 2009 07:01 PM
JolietJake
Apr 16, 2006 11:22 AM
