4x4 fuse (#15) keep blowing
Old Aug 30, 2010 | 04:54 PM
01blueblaze's Avatar
01blueblaze is on a distinguished road
Default 4x4 fuse (#15) keep blowing
The fuse blew a couple weeks ago and everytime ive tried to replace it it blows again just seconds after starting the truck. I removed the kick panel and found that there was corrosion on the female end of the harness, tugged on the most corroded wire (number one, grey+blck) and it broke right off by the looks of it. Im wondering what the next step is? Im tempted to get a used harness and just cut the wires and hardwire it but as you can probably tell i dont know much if anything about this. Any help would be great, thanks.
Old Aug 30, 2010 | 08:43 PM
That fuse powers the TCCM, dash switch, front drive engagement switch, PCM, and the front axle engagement solenoid - wiring schematics - NV236 Wiring Information. Any one of those items could be causing it to blow, but the TCCM is the most common. Check for corrosion on the connector terminals at the TCCM (located behind the passenger side kick panel).
Old Oct 16, 2010 | 01:39 PM
Default Next step...
Okay so there is corrosion on the tccm connector, i finally found the time this wkend to work on it and i cleaned it all up, one wire was extremely corroded and broke when i touchedit so im going to put another pin on it and see if it works but i was wondering if the tccm is fried now or if this will work for now...also wondering what a used tccm costs roughly
thanks
p90tr8
Mar 18, 2014 05:56 PM
Hank3band
Sep 20, 2011 09:08 AM
NYCJUDGE
Aug 28, 2011 04:35 PM
JolietJake
Apr 16, 2006 11:22 AM
