LED Taillight installation problem
Old Apr 25, 2012 | 05:40 PM
r0k0's Avatar
r0k0 is on a distinguished road
Default LED Taillight installation problem
Hey guys, bought a set of Black LED tails and i went in a problem
#1, they don't have LED resitors in them.. thankfully i have some from VLEDs.com
#2, they have 1 connector but we have 2 bulbs in stock tails
Uploaded with ImageShack.us
any of you LED guru's or even soldering guru's have a idea to by-pass the second connector to read that i only have 1 bulb installed to put my load resitor on and make my led blink normal speed and not hyperspeed
Here are the picture of the tails
Old Apr 25, 2012 | 06:18 PM
xgiovannix12's Avatar
just upgrade to an led flasher relay
you can use both regular bulbs and leds like this
superbrightleds have them
some local auto parts sell them also
Old Apr 25, 2012 | 06:31 PM
r0k0's Avatar
so that will just cancel the 2nd not used connector ?
Old Apr 25, 2012 | 06:36 PM
yep just remove the bulb and put it where it originally sits
Old Apr 25, 2012 | 06:40 PM
r0k0's Avatar
do you have the correct part number... they have some but dunno which is and dont wanna buy the wrong one, alsoi plug the LED in 1 of the socket and leave the other one empty and this should make my led flash normally even with a empty socket ?
Old Apr 25, 2012 | 06:46 PM
with the led relay yes and no i dont have the proper part number
but if you pull the old one you should be able to match them up to get the one made for leds
Old Apr 25, 2012 | 06:58 PM
r0k0's Avatar
oh ok :P cool i'll seek them out them, where is the relay for the flashers ?
also i have no power going to my fuse for reverse light... any ideas ?
Old Apr 25, 2012 | 08:26 PM
Rottidog's Avatar
The relay is behind the glove box. Squeeze the tabs that stop the box from falling out & it will dump all the contents on the floor lol.
No power to the fuse is odd, are you sure you're checking the right fuse?
Old Apr 26, 2012 | 08:02 PM
r0k0's Avatar
yeah book says veh b/u which is the back up light for truck and i get no power to it
Old Apr 26, 2012 | 10:03 PM
richphotos's Avatar
Looking at the tail lights you got, I am confused, I know the top section has LED's, does the middle section have nothing at all in it? It looks like it should have a bulb in there?
Wait, nevermind, thats the reverse light, isnt it? LMAO!
