lonnie
Old Nov 4, 2013 | 07:15 PM
lonnie s's Avatar
lonnie s is on a distinguished road
Default lonnie
led lights for park,r,n,d,low dont work. is there a fuse or is it body control 2001 blazer s-10
Old Nov 4, 2013 | 09:50 PM
richphotos's Avatar
Is it a digital display for what gear you are in, or is it the manual rod moves across to show what gear you are in?
if its digital, its probably a problem with the cluster itself. there is no fuse for this.
if is the analog style where the rod moves, then it could just be an out bulb..
Old Nov 5, 2013 | 02:19 PM
lonnie s's Avatar
its digital also when this happened the transmission was stuck in high gear trans is now ok but the digital lights and all the lites for abs,battery,brakes,towing etc not working
