Lost wire/plug cant find its home
Old Aug 24, 2013 | 06:57 PM
Xspoilerx's Avatar
Xspoilerx is on a distinguished road
Default Lost wire/plug cant find its home
Just got done changing the intake gaskets on a 2002 blazer and i have one plug i cannot find where it goes here is a pic maybe someone would know off hand
Where it belongs i cant see anything as to where i could go it was definitly plugged in because it is clean . . Thanks in advance
Old Aug 24, 2013 | 07:07 PM
Xspoilerx's Avatar
Here are the pics... In the photo the covered wire that runs into the bigger harness is where the pug is coming from
Attached Thumbnails Lost wire/plug cant find its home-image.jpg
Old Aug 24, 2013 | 07:10 PM
Xspoilerx's Avatar
Pic of connector
Old Aug 25, 2013 | 09:05 AM
Spree's Avatar
Spree is on a distinguished road
Not sure can you see it in these pics? Got a lot more pics if you need any.
Attached Thumbnails Lost wire/plug cant find its home-3.5-hours-1-.jpg   Lost wire/plug cant find its home-3.5-hours-2-.jpg   Lost wire/plug cant find its home-3.5-hours-3-.jpg
Old Aug 25, 2013 | 09:11 AM
Spree's Avatar
How about these...maybe they can help.
Attached Thumbnails Lost wire/plug cant find its home-finished-2-.jpg   Lost wire/plug cant find its home-finished-4-.jpg   Lost wire/plug cant find its home-finished-5-.jpg
Old Aug 25, 2013 | 07:16 PM
KENTUCKYMEL's Avatar
KENTUCKYMEL is on a distinguished road
i cant see, im blind in one eye can't see out the other lol. check for a plug in right in the middle, front of the engine, on the radiator hose pipe flange. i have the opposite problem, never have found the plug in that goes there on my bravada. i cant see the plug very good in your picture so im taking a guess on your plug. it has the same shape as the receiving end on my bravada, but its a 98 model so yours could be different. don't know what its for really, as my temp gauge works, as do all gauges, maybe has something to do with the air conditioning system. hope this helps you, im still looking in case it doesn't.
Old Aug 25, 2013 | 10:12 PM
Spree's Avatar
It looks like the blue connector that plugs into the ac compressor.
Old Aug 26, 2013 | 02:37 AM
Jakeduece's Avatar
Jakeduece is on a distinguished road
There's a plug underneath the distributor cap, on the back side. Did you plug that in? That's all I can think of.
Old Aug 26, 2013 | 05:56 AM
Xspoilerx's Avatar
Ya when I look at the pictures the one going to the ac compressor always gets me but I have that one plugged in. That one is a 4 pin its a lot wider than the one I am trying to find. I know the distributed one is plugged in .
The plug and wire comes out of the larger harness right behind the upper intake it's about 2 1/2 ft long so it could reach a couple different areas. It has a plastic clip on it where it goes into a bracket but I don't see where
Old Aug 26, 2013 | 06:41 AM
Bowtie2500's Avatar
Bowtie2500 is on a distinguished road
Temp sensor between cylinder 3 and 5 near steering shaft.
