My blazer is reading the wrong outside temperature?!
Old Jul 11, 2013 | 07:20 PM
blazerxtreem's Avatar
blazerxtreem is on a distinguished road
Question My blazer is reading the wrong outside temperature?!
Hello,
I have a 96 Chevy blazer LS. The thermostat/compass is always reading 121 degrees Fahrenheit... What do i do? How can I solve this problem?
Thanks
Old Jul 11, 2013 | 08:08 PM
Thogert's Avatar
The new member area is for introductions only.
**Moved to lighting & electrical**
Old Jul 11, 2013 | 08:15 PM
Oh my bad.
Old Jul 11, 2013 | 11:21 PM
richphotos's Avatar
There are a few things you can do, you can reset it, which would involve holding down both buttons for a few seconds until it is reset. if that does not work, check the connection on the temp sensor (right behind the grille, the center post on the core support (middle of the truck) if the connector is good, you may need a new temp sensor.
Once you reset it, you will need to calibrate the compass as well. which all you need to do is find drive it around in a circle 3 times until "cal" goes away. I would recommend resetting it in a parking lot, so you can calibrate the compass at the same time.
Old Jul 12, 2013 | 09:03 AM
Okay. I tried the reset. Didn't seem to work, but I have a question.. it was saying VAR when i reseted it and beside VAR it had had numbers that you could cycle through 0-15. I don't know what that is, but I'm trying to find the temperature sensor. where can i find one to replace it? any sites around here?
Old Jul 12, 2013 | 10:54 AM
richphotos's Avatar
Try rock auto, GM dealer ect, or even a pull it yard, LMC truck, I'm sure people will have other suggestions.
As for the VAR, I am not sure what that is, or means?
Old Jul 12, 2013 | 12:20 PM
Alright thanks.
Can you show me a pic of what im looking for exactly. I have no clue.
Old Jul 12, 2013 | 07:09 PM
richphotos's Avatar
I cant find a photo of it, but its literally right in the middle of your grille, attached to the radiator core support.
Old Jul 12, 2013 | 07:45 PM
Alrighty I see it now! Thanks
Old Jul 12, 2013 | 07:56 PM
richphotos's Avatar
You are welcome.
