Need advice on wiring
Old Sep 28, 2019 | 05:31 PM
Kevin Murphy's Avatar
Kevin Murphy is on a distinguished road
Default Need advice on wiring
I have a 98 blazer. When I start the vehicle headlights come on tail lights come on but the instrument panel does not work I could drive down the road and no speedometer and no tack gas gauge don’t work radio doesn’t work cigarette lighter doesn’t work dome lights don’t work but when I turn on the headlights everything works that means that there is something amiss with the wiring and would like some Input on what it might be
Old Sep 28, 2019 | 08:17 PM
It sounds like you could have a problem with the ignition switch. Check out the following link --> Anatomy of the Ignition Switch. It should have all of the information you need to test the ignition switch. I just added some new information towards the bottom of that tech article today that makes testing three of the ignition circuits quite a bit more user friendly. If you have any questions, please post up! Let us know your results as well!
rickrobertson
Oct 2, 2019 07:22 PM
poertsch
Jan 3, 2012 07:31 PM
albrightc
Aug 11, 2011 05:16 PM
recruiter
Jan 5, 2007 02:58 PM
Camper2
Dec 9, 2004 05:45 AM
