need help with gas gauge.
Both are common issues that are covered fairly well in the Tech Article (DIY) section. Check out the link to the index of this section in my signature below.
The blinker issue is most likely a faulty hazard switch which is part of the multifunction switch. It can be replaced independently as covered in the tech article section.
The gas gauge needs to be diagnosed. Again, the diagnostic procedure can be found in the tech article section.
When I got my 00' Jimmy the fuel gauge didn't work. Turned out to be the sending unit on the furl pump was shot, and unfortunately it can't be changed independently. Gotta get a whole new fuel pump. But ganged mine and it wires now.
If you decide to change the pump only use ac delco or bosch fuel pump assemblies, airtex may seem like alot of money saved but they tend to go right back out again. Is your needle above full or is it sitting at empty at all times?
I have a 97 blazer 4x4 lt 4 dr and my gauge stays past full. Any input would be great!
. so i am gonna have to drop the tank to fix it. yay.
