need help, led tail light bulbs
Old Jul 11, 2012 | 06:05 PM
bobby099's Avatar
bobby099 is on a distinguished road
Default need help, led tail light bulbs
well i have a 98 blazer i ordered some led tail light bulbs to replace my old reg tail light bulbs now heres the werid part i just plugged them in and they dont work i tried both ways no luck. so i just plugged them in where my white led reverse lights are they work with no problems. so i thought maybe something was messed up so i just plugged my led reverse lights in my tail light socket and they dont work either. now does this mean i need a resistor?
Old Jul 11, 2012 | 06:43 PM
bobby099's Avatar
anyone?
Old Jul 11, 2012 | 09:52 PM
Thogert's Avatar
It sounds like you have a wiring issue. I'd check to see if you have power to the bulbs at all first. If not, then check the grounds and go from there.
Old Jul 12, 2012 | 04:17 PM
bobby099's Avatar
well thats what i thought but i had reg brake bulbs in and they worked just fine but when i plug in my led brake bulbs in the sockets they dont light up but when i turn my turn signals they turn on with no problems but then ill turn off my blinker they shut off
Old Jul 13, 2012 | 02:26 AM
Thogert's Avatar
Ok there is a possibility that you got the CK style bulb, which would cause an issue like what you describe. Here is a diagram that shows how the regular and CK style are different.
This could be the issue. Take a look and see if your bulbs say CK on them somewhere.
Old Jul 13, 2012 | 08:18 AM
bobby099's Avatar
thanks but i think i found the problem there single filament bulbs after the ebay seller told me they were dual filament bulbs i cant you cant trust ebay for that reason
bobby099's Avatar
so when i buy the next set of bulbs could you tell me what to buy someone told me to get dual filament bulbs is that right
Old Jul 13, 2012 | 08:41 AM
Thogert's Avatar
Yes, dual filament. 3157 NOT 3156 they are not interchangeable.
96jimmyslt4x4
Sep 21, 2011 09:14 AM
CNYCountryKidd
May 19, 2010 06:46 AM
danmiranda
Apr 8, 2010 08:50 PM
litterbug
Feb 3, 2010 04:31 PM
spankyy
Nov 12, 2009 11:06 PM
