Need non-ac wiring diagram for efan swap
Old Dec 30, 2012 | 05:05 PM
chris015's Avatar
Default Need non-ac wiring diagram for efan swap
Doing a taurus fan swap in a week or 2. I removed my ac,and all i can find is ac diagrams. I will only be using the low side of the fans since high side pulls a load of amps on start,and is not needed since i dont have ac anymore. If you can help id appreciate it.
Old Dec 30, 2012 | 06:19 PM
xgiovannix12's Avatar
cant you pull power straight from the battery ? How is this fan going to kick on? when the engine hits a certain temp ?
Edit: after some research I dont think you connect it any where since the ac got deleted. You can hook it up on something else that would make the engine run hotter then usual .
Old Dec 30, 2012 | 06:51 PM
chris015's Avatar
I'm going to run a thermostat control system with a relay. I could indeed run it in a simple way but i only want it coming on when the temp hits whatever i set it at. Fans pull amps,and my lil 105 alt doesnt like my subs,fans,etc working together full time. i needa do the ad244 upgrade too.
Old Dec 30, 2012 | 06:53 PM
ahh ok that makes sense now.
Old Dec 30, 2012 | 07:08 PM
richphotos's Avatar
Dont they sell thermostats that are designed for this specific reason to kick the electric fans on when it gets hot?
edit.. I am drunk... second edit... your alt cant handle it? how much power are you running to your subs?
Old Dec 30, 2012 | 07:41 PM
chris015's Avatar
900 rms at 2 ohms. My voltage doesnt drop at all until the heater is on high and lights are on with the subs going. If everything off but the subs and lights its fine. I just know that installing the taurus fans its going to put some stress on my alt with everything else on.
on another note,richie wheres that bottle of yager i was suppose to get for cmas? lol
Old Dec 30, 2012 | 09:33 PM
richphotos's Avatar
Dude, I will get you one and mail it to you LOL
On a side note, what amp do you have, I am running 750w at 2 ohms, soon to be 1000w at 1 ohm, and did the big 3, and have the headlight retrofit with the relay harness, I can bang at full volume, have the heat or AC on, and headlights, and the voltage stays at 14.
I am running a class D monoblock amp though, they are extremely efficient.
Old Dec 30, 2012 | 09:48 PM
chris015's Avatar
im running a mono block as well. the gauge needle sits right under 14 with everything on full tilt. It just bugs me looking at it lol.
Old Dec 30, 2012 | 09:53 PM
richphotos's Avatar
I have the digi, and they are known to be inaccurate, so maybe I am just under 14, hell, if my headlights dont dim, I could care less LOL
especially when the windshield wiper arms are jumpin.
phxjosh
Oct 30, 2013 10:03 AM
Bob97
Jan 24, 2008 08:42 PM
cfnb
Nov 7, 2007 05:32 AM
ridered600
Sep 14, 2006 07:58 AM
chris
Dec 6, 2004 12:47 AM
