need some help
hey guys just wondering if anyone can help me out here....
so i went to the groc store and bought groc. opened the rear window, opened no problem...drove 20 mins home, went to get them out, nothing. my rear window wont open. i tried the button on my dash and on the key fob. im not hearing anything click, but the lights do flash. i also tried with my key to open it manually, and it still wont open. its a 99 blazer if that helps. thought maybe a fuse or a poor ground. need help tho guys. thanks
might be the latch motor. you'll have to get access to it by removing the trim/covering over the latch. which means you'll have to somehow get the window open. sometimes there is 2 bolts on the inside of the glass, and on either side of the latch. remove thoseand the glass should open up, and you should be able to access the latch motor
davidluzader
03-01-2010 10:25 AM
rcravincase
09-13-2009 07:58 PM
ZLover4Life
46
12-22-2008 01:01 AM
scottyk
03-19-2007 11:32 PM
