New blower motor,new resistor, no power
I have a 98 blazer with auto climate control ,I have replaced both blower motor and resistor and still no blower power. What am I missing? Please help
Thread moved as per rules in the New Member section.
A volt meter is missing. Throwing parts in at random often doesnt work as you've discovered. Time for a wiring diagram and volt meter and tracing from the circuit fuse towards the motor to see where the circuit us broken.
The littie $5 meters from Harbor Freight work well. Ive used them to measure 1,000 volt power supplies. |
1 Attachment(s)
Auto climate control takes a different blower motor and uses a power module, not a resistor. See attachment. This could be your problem. Wrong parts!
Everyone thanks for all of your inputs, however this problem was solved weeks ago. It was a blown fuse but I have since then posted another issue concerning the blower running continuously after power has been shut off.
Originally Posted by iceblue068
(Post 726648)
Is that part separate from the resistor itself? If so, where is it located?
6 Attachment(s)
(Post 726661)
Typically a blower motor that takes too much current is the cause for the power module going bad and staying on all the time - a common problem. Check your blower motor draw or replace the blower motor before replacing the ECC module. ---------------------------- Electronic Climate Control (ECC) Module (w/ Auto A/C) At the IP harness center of the IP, below the radio HVAC Component Views (see attachment) |
Thanks, I will try that. Now to be clear, the single wire that is connected to the harness that plugs into the blower motor, is that some type of ground? I wish I could send you a picture of it. In the meantime, I will be working on the ECC issue. Thanks again.
Schematic in post #4 shows the orange wire is the power feed coming directly from the fuse (hot all the time). The purple/white wire is the PWM speed control wire from the ECC module. The black wire is the ground.
