New blower motor,new resistor, no power
Old Aug 8, 2020 | 09:49 PM
iceblue068's Avatar
iceblue068 is on a distinguished road
Default New blower motor,new resistor, no power
I have a 98 blazer with auto climate control ,I have replaced both blower motor and resistor and still no blower power. What am I missing? Please help
Old Aug 14, 2020 | 03:00 AM
Thread moved as per rules in the New Member section.
Old Aug 14, 2020 | 03:47 AM
daveca's Avatar
A volt meter is missing. Throwing parts in at random often doesnt work as you've discovered. Time for a wiring diagram and volt meter and tracing from the circuit fuse towards the motor to see where the circuit us broken.
The littie $5 meters from Harbor Freight work well. Ive used them to measure 1,000 volt power supplies.
Old Sep 1, 2020 | 10:42 AM
LesMyer's Avatar
Auto climate control takes a different blower motor and uses a power module, not a resistor. See attachment. This could be your problem. Wrong parts!
File Type: pdf
Old Sep 1, 2020 | 03:11 PM
iceblue068's Avatar
Everyone thanks for all of your inputs, however this problem was solved weeks ago. It was a blown fuse but I have since then posted another issue concerning the blower running continuously after power has been shut off.
Old Sep 1, 2020 | 08:02 PM
LesMyer's Avatar
That would be a fried power module
Old Sep 1, 2020 | 08:16 PM
iceblue068's Avatar
Is that part separate from the resistor itself? If so, where is it located?
Old Sep 2, 2020 | 01:17 PM
LesMyer's Avatar
Where in the schematic I previously sent you do you see a resistor? THERE IS NO RESISTOR on Auto A/C. On this vehicle the blower power module is called the ECC Module. See below.
Typically a blower motor that takes too much current is the cause for the power module going bad and staying on all the time - a common problem. Check your blower motor draw or replace the blower motor before replacing the ECC module.
Electronic Climate Control (ECC) Module (w/ Auto A/C)
At the IP harness center of the IP, below the radio
HVAC Component Views (see attachment)
File Type: pdf
Old Sep 3, 2020 | 04:46 AM
iceblue068's Avatar
Thanks, I will try that. Now to be clear, the single wire that is connected to the harness that plugs into the blower motor, is that some type of ground? I wish I could send you a picture of it. In the meantime, I will be working on the ECC issue. Thanks again.
Old Sep 3, 2020 | 07:37 AM
LesMyer's Avatar
Schematic in post #4 shows the orange wire is the power feed coming directly from the fuse (hot all the time). The purple/white wire is the PWM speed control wire from the ECC module. The black wire is the ground.
Andrew Wood
Apr 19, 2017 08:22 PM
4x4Eddie
Mar 14, 2013 07:04 PM
Jimmy91
Jan 16, 2012 09:08 AM
Zukadog
Jul 23, 2011 04:08 PM
EnyChevyUK
Aug 25, 2009 07:24 PM
