no turn signals
Old Dec 20, 2011 | 04:36 PM
00blazer13's Avatar
00blazer13 is on a distinguished road
Default no turn signals
2000 s-10 4wd ls. My hazard light switch was jammed since I bought the truck. I saw a post that said you can pull the switch out. I tried that, it popped up and I have hazard lights now and no turn signals. I did not remove the switch. I have to pull the switch up to make the hazards work, push down to turn off. There is no feeling of it being spring loaded.If I move it slowly up and down the left light will blink but the right one stays on. Fuses are good. I have noticed a clicking sound when I am driving, for no apparent reason. That was before I messed with the switch. Any help would be greatly appreciated.
Old Dec 20, 2011 | 05:54 PM
You can try to replace just the switch itself, but it sounds like the problem is deeper down in the multifunction switch. Check out the Tech Article (DIY) Index link in my signature for a walk thru for both the hazard switch & the complete multifunction switch. PNs are listed as well.
Old Dec 20, 2011 | 08:39 PM
00blazer13's Avatar
Does the hazard switch connect to the multifunction switch?
Old Dec 20, 2011 | 09:01 PM
xgiovannix12's Avatar
yes but the hazard switch its self is replaceable on 95 + models
the 2 links show you how its done
https://blazerforum.com/forum/tech-a...acement-37435/
https://blazerforum.com/forum/tech-a...-repair-29168/
SubbinBlazer
May 24, 2013 12:56 PM
BlaZeR FXB1581
Jan 22, 2006 11:51 AM
BlaZeR FXB1581
Sep 2, 2005 07:41 PM
mendez918
Mar 3, 2005 11:42 PM
blazin97
Feb 22, 2005 01:49 AM
