-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   no wipers or sprayers but everything else works (https://blazerforum.com/forum/lighting-electrical-52/no-wipers-sprayers-but-everything-else-works-73206/)
thiefinthenight Aug 23, 2012 03:04 PM
hey guys im new here but not new in the automotive world. i purchased a 2000 blazer that had minor mechanical issues and a few electrical issues. i keep replacing parts and fixing problems only to get a new problem. so maybe someone here has dealt with this issue and can point me in the right direction.
i had removed the manual seats and installed power seats and they worked at first. then they stopped working and the battery kept dying as well so i searched and found a badly corroded and loose connection under the rear carpet and fixed that issue so the seats worked and the battery no longer drained.
then ignition switch main power wire had rubbed against the collumn so much it was exposed and soldering to it. so i replaced the ignition switch. and was greeted with a ses light. turns out it was for the shift solenoid b in the transmission. i replaced that and no more ses light.
but now somewhere between fixing these things the wipers (front, rear, and both pumps) are no longer working. they were before and now they are not. the signal works the cruise as far as i know work (cant tell because bulb is burnt out and wont display and havent driven it to find out) so now i have tested for power at the fuses to the wipers and i am not getting power to them. so now i am at a loss.
could i have shorted something to cause this problem or is there a relay i can test or may not have grounded? any help would be appreciated.
thiefinthenight Aug 24, 2012 03:22 PM
oh i also forgot to mention i have replaced the multifunction switch with one i got from a know working blazer that my buddy junked and that has not fixed the problem either. so any advice would still be great.
thiefinthenight Aug 25, 2012 11:03 AM
ok so im trying to sumarize my problems so maybe ill get some responses.
i have no wipers and sprayers front or rear but i do have signals and cruise.
so i have replaced the multifunction switch and just replaced the wiper control module and still no dice.
any suggestions?
