Not starting issue 2001 Blazer 4.3
Hey guys this is my first post so I'm sorry if you have answered this already. I have been having trouble getting the car to start for a few weeks, it usually will go after a few tries. When I turn the key to the run position the lights turn on and the fuel pump runs, but when i turn it to the start position nothing happens. No sounds or cranking. In those few weeks I have tried cleaning connections, changing fuses and relays, replacing ignition (switch and harness), and replacing the starter (I thought the solenoid was bad). Now it won't start at all unless I jump the solenoid. Im going to check the wiring from the fuse box to the starter next but its a mess and I don't really want to get into that. Any recommendations before I do?
gettinbrushless
Aug 13, 2016 12:47 PM
nhicks
Sep 23, 2011 03:01 PM
