One low beam wont turn on, but both high beams will
Old Dec 28, 2013 | 08:39 PM
dflanigan's Avatar
dflanigan is on a distinguished road
Default One low beam wont turn on, but both high beams will
All of the lights work except for one low beam headlight. The running lights work just fine but when you flip on the lights only the passenger side headlight works. Although, the high beams work just fine for both headlights which are from the same light bulb. I tried replacing the light bulb first but it did nothing. The drivers side low beam headlight still will not turn on.
Old Dec 28, 2013 | 11:49 PM
abig84's Avatar
check the positive side of the socket to make sure its got power going to the socket with the switch turned on. sometimes the sockets go bad
Old Jan 3, 2014 | 06:06 PM
dflanigan's Avatar
Do you know where the ground would be though for the low beam driver side? I am having difficulty hunting it down. There is no power at the plug or before it. (I stabbed a little hole in the wire just to check to make sure it was not the plug) I also replaced the switch on the dash for the lights hoping that would fix it. Although, there is still no power.
1998LT
Apr 1, 2011 01:07 PM
marine
Jan 28, 2010 07:05 PM
portcqb
Oct 5, 2008 07:22 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
