Parasitic battery drain
Old Oct 24, 2022 | 06:01 AM
DH1966's Avatar
DH1966 is on a distinguished road
Default Parasitic battery drain
1987 K5 LS swap, couple weeks into driving the truck my battery died, found a major battery draw when the the truck is off (6-7 amps on the ground) so far traced it back to the power lead going to the fuse block, pulled all fuses didn't make much difference other then when I pulled the dome and courtesy lights. Could this be a fusible link, no blown fuses, disconnected my blower fan and relay didn't make any difference, any help would be appreciated
Old Oct 24, 2022 | 07:07 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
What do you mean, "didn't make much difference other then when I pulled the dome and courtesy lights"? Did pulling their fuse stop the drain?
Old Oct 24, 2022 | 07:24 AM
DH1966's Avatar
Sorry no it reduced it by approx. 1 to 1.5 amps but that was over an above the 6.5 amp draw, once I opened the doors the draw increased to 7.5 to 8 amps
Old Oct 24, 2022 | 08:14 AM
OK. Is there another fuse box that's fed from that lead that does not go through the fuse box you're working with? You should be able to pull all of those fuses and eliminate all draw.
Old Oct 24, 2022 | 08:53 AM
DH1966's Avatar
No it has the stock blazer fuse block, it does have a small block that came with my new PCM wiring harness for the main power and duel relay, I will check these and see if it makes any difference. When I wired the truck I came off the starter with a large gauge fusible link to a buss bar, from there I ran to the main fuse block, then wired my electric fans, power window relays etc directly to the buss bar. I removed one wire at a time from the buss bar until the amps dropped and that was how I found what wire was causing the issue.
Lyricalsalvation444
Dec 10, 2017 11:33 PM
elch
Feb 17, 2014 08:53 AM
newguy
Jan 4, 2014 07:28 AM
masterchf117
May 2, 2010 02:18 PM
NVANZEE
Sep 27, 2008 03:25 PM
