Parking lights and dashboard lights are out
Old Aug 7, 2017 | 04:07 PM
Mort1312's Avatar
Mort1312 is on a distinguished road
Default Parking lights and dashboard lights are out
New member, first post. Forum looks very good. 1998 Blazer LS w/ V6
Pulled into work one morning after sunrise, so the DRL headlights were on.
Turned off engine and removed key. The front parking and tail lights were ON. Messed with ignition switch and key, lights went OFF. The key lock cylinder has problems. Came out from work and the battery was dead. Hooking up jumper cables the lights came back ON before inserting key. This went on for two days.
Hooked the battery back up on the third day, no light came ON. YEA! That night, started the engine and no lights came ON. Five days later and a new key lock cylinder, still no front parking or tail lights turn ON. The instrument panel is also dark.
The clock and overhead temp and compass displays are ON when the DRL lights are ON. When the main headlamps turn on at dusk, these displays turn OFF. The emergency flashers, brake lights and turn signals work fine. The headlight switch only keeps the main headlights ON after dark, and will not turn them ON during daylight.
So far the fuses and the relays check out, by swapping out relays.
Any ideas as to the reason behind the temperamental lights?
rylan9
Aug 29, 2012 12:37 PM
bbkld5
Jan 31, 2011 10:10 PM
robertabuck
Nov 29, 2010 05:43 PM
Jebs99
Oct 3, 2008 12:57 PM
DCFluX
Oct 5, 2006 04:23 PM
