Passenger door lock connector
Old Sep 12, 2011 | 07:36 PM
tsutton's Avatar
tsutton is on a distinguished road
Default Passenger door lock connector
I was replacing the passenger door speaker and accidentally crushed then cut off the two-pin female connector that goes to the power lock switch. Before I noticed the mistake I pitched the connector. I've searched and can't find the part number for the connector/harness.
Can anyone help.
Thanks.
2000 Blazer ZR2
Old Sep 12, 2011 | 08:34 PM
What color were the wires? I show a 3 cavity connector that has only two wires to it (black & brown), but that is for the illumination ground & power. The PN for that connector is 12047781.
Old Sep 13, 2011 | 01:48 PM
tsutton's Avatar
Attached are pictures of the bottom of the switch and the cut off wires. The switch connector does looke like it has room for a three wire connector although only two would be used. The wires appear to be brown and black (maybe really dark blue). What do the wires power? The interior lights work as expected.
Is there somewhere you can buy the connector with wires already attached so I can just splice the loose ends?
Thanks!
Forgot the pics...
Thanks!
Attached Thumbnails Passenger door lock connector-cut-wires.jpg   Passenger door lock connector-passenger-door-switch.jpg
Last edited by swartlkk; Sep 13, 2011 at 01:54 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 13, 2011 | 01:53 PM
Those two wires are only for the back lighting of the switch itself.
The connector PN I referenced is the correct one for your application. I am not sure if it will include the terminals & a length of wire or not... You likely will have to get two unsealed metri-pack series 150 terminals & crimp them onto some new wire to add length to the harness for easy service.
*EDIT* - Added the connector pinout:
Old Sep 13, 2011 | 03:33 PM
tsutton's Avatar
Thumbs up
It is so hard to find information on parts when you aren't sure what terms to search on. You have definitely been a big help.
Thanks!
Old Sep 13, 2011 | 03:43 PM
No problem! Glad to help!
bryanhodki
Jan 26, 2014 04:55 PM
ChaseHammer
Aug 15, 2012 01:36 PM
ussexplorer
Apr 9, 2010 11:49 PM
bigdaddykane93
Dec 6, 2009 05:28 PM
treysanatomy
Nov 3, 2009 02:00 PM
