Passlock problems
Hi all, I have a question to ask about my 2000 gmc sonoma 4.3. I know it isn't a blazer, but I was wondering if you guys would help anyways.
I've been pulling my hair out trying to figure this out. My truck starts for a few seconds, then dies. The security light would stay on solid after it ran, which I found out means that there is a fault in the system somewhere. I tried splicing the yellow wire to the orange and black wire like many people say, but that did not solve my problem. It allowed me to reset it, but it still starts, but wont run.
I guess it could be fuel pump, but why would the security light be on?
thanks a lot,
Zac
thanks a lot,
Zac
thanks a lot,
Zac
thanks a lot,
Zac
Thanks man! The bypass I described above should have ruled out the ignition switch, but I don't know for sure.
Good fuel pressure from what you posted... I am wondering how the security light thing ties in though??? Maybe some kind of bad sensor? I am a rookie on here compared too most of these guys, so I bet someone will jump in soon and help you out...
at least my ignition is buttery smooth now 😄
Have you checked your fuel filter? It will start and run a few seconds you said and then die... Could your fuel injectors be all clogged up? Come on you guys, jump in and help him out, I know you are out there
I have a 2004 Chevy Blazer that I lost my key and tried to hotwire it by tearing out the ignition switch housing or whatever I finally figured out where the starter wire was located and it will turn over but not start. I'm thinking that it's a pass lock issue and I don't know what to do about it could someone please advise me
The passlock module in the ignition assembly presents a unique resistor value to the computer to allow the vehicle to start. You hack the wiring, place a resistor in the circuit and then perform a passlock relearn. After this hack the anti theft security feature will no longer work but the truck will start. If you have wiring/soldering skills and know how to read a resistor color code or have a digital meter let me know and I can walk you through the process.
The proper way to fix it is to replace the lock cylinder and passlaock module and perform the relearn.
George
George
