Power seats, help please!
Is there any way to raise and move both driver and passenger seats on a 98 or newer Bravada? Trying to salvage ta pair from the junkyard and theres no power or steering assemblie to be able to change that.
Yeah that!! Make sure the fuses are intact still!!
Lol yep fuses were gone . I called dealer and they said its a circuit breaker actually. I found one blazer in tact so I stripped all fuses and they worked. Driver seat won't move forward though . Everything else is good though . Any ideas?
Will a non memory switch work on a memory programmable seat? I was thinking I could switch the control panels back and fourth and just set the memory for me and my gf.
That's assuming its just a switch problem of course.
I'm almost don with replacing the entire interior.
There was another gentlemen there so i tried pushing from behind as he told it to go forward with no luck. Its all the way back I'm getting ready to install driver side now. My thought's are a bad switch I can here it activate to go backwards but not forwards.
There is a plastic tube that houses a flexible shaft that connects the seat forward/backward motor from the left seat track to the right seat track. Make sure this is still in place. Often times they get yanked off by someone who thinks the seat is a manual. If it's missing, only the drivers side track will move and it will get cockeyed and the seat won't move at all unless you manually move the right side track.
Hans
Hans
