power window issue
Old Feb 3, 2016 | 01:17 PM
kobster80's Avatar
kobster80 is on a distinguished road
Default power window issue
I'll admit this problem is in my 90 C2500 but the systems are pretty much identical as far as wiring goes. My passenger window doesn't want to go down, and I know exactly why just not sure what's causing it. For whatever reason I'm not getting a negative. Positive and negative are fine for up just not down. If I feed a negative to the blue wire, even from the door, it'll go down just fine. It's not the switch, I've swapped every switch to find the same problem. Same issue controlling from both doors. I'm baffled.
Old Feb 11, 2016 | 02:06 PM
LesMyer's Avatar
I would suspect the door lock and window switch driver if the problem is the same from multiple switches on both sides of the vehicle.
Old Feb 12, 2016 | 03:05 AM
kobster80's Avatar
Nice, that's a schematic I haven't seen yet. Thanks! Don't suppose you know where said driver is located before I go tearing my dash apart looking for it?
Old Feb 12, 2016 | 07:33 PM
Both wires at each motor default to ground. When a switch is activated, it removes one of the grounds, and applies voltage. Start probing wires until you no longer show a ground.
e602
91
Mar 8, 2015 04:53 PM
bigslik20
Aug 9, 2011 11:32 AM
GolfClapperX
Jun 5, 2009 03:48 PM
Valafar
Mar 30, 2009 07:49 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
