power window relays 1987 s10 blazer 2dr
No relays. Just a ac relay and fuel pump relay.
If both are dead,Its either the main window switch(which is on the drivers side) or a broken wire between the door and the cab. Pop the little rubber boots loose and check all the wiring. Mine was a solid black wire that was broken.
raider1969
Mar 18, 2015 01:20 PM
K5Blazer87
May 28, 2014 01:35 PM
wesmagyar
Jan 24, 2008 10:28 PM
1987s10blazer
Oct 26, 2007 09:47 AM
