power window relays 1987 s10 blazer 2dr
Old Mar 16, 2012 | 08:08 PM
knitter0217's Avatar
knitter0217 is on a distinguished road
Default power window relays 1987 s10 blazer 2dr
Are there relays? If so where are they and how can I tell if they're bad? Both windows won't move
Old Mar 16, 2012 | 08:16 PM
chris015's Avatar
No relays. Just a ac relay and fuel pump relay.
If both are dead,Its either the main window switch(which is on the drivers side) or a broken wire between the door and the cab. Pop the little rubber boots loose and check all the wiring. Mine was a solid black wire that was broken.
Old Mar 17, 2012 | 08:00 AM
K thanks. I was planning on pulling the door panel off today
raider1969
Mar 18, 2015 01:20 PM
K5Blazer87
May 28, 2014 01:35 PM
eagle1971
Jul 6, 2013 04:29 PM
wesmagyar
Jan 24, 2008 10:28 PM
1987s10blazer
Oct 26, 2007 09:47 AM
