Power windows just quit
Old Sep 8, 2016 | 01:51 AM
deputydawg190's Avatar
deputydawg190 is on a distinguished road
Default Power windows just quit
I have had this 1999 S10 Blazer for less than a month. The other day I rolled the drivers window down, when I tried to roll the passenger window down- Nothing. Now none of the windows work from any control. I appear to have no power to the driver side controls. All the fuses are good. Locks and mirror work. Any wiring diagram I have looked at states there is a 30 amp circuit breaker (somewhere). Anyone have any ideas where I can find this allusive C/B. I have the dash, cluster pulled out and can't find it. Tired of getting wet
Old Sep 9, 2016 | 12:57 PM
abig84's Avatar
its common for the wiring in the driverside door jam to break. also a lot of the times when you lose all your windows its the driverside door switch panel as the power seems to run through that first. you can try rolling up a window and wiggle the rubber boot in the door jam
Old Sep 16, 2016 | 11:28 PM
ski9600's Avatar
ski9600 is on a distinguished road
So my left side front window motor quit operating and I replaced the switch which was feeling flaky to touch but that didn't fix it. Today we took the door panel off to test/replace the window lift motor. The power supply to the motor is working properly. The motor is riveted in and caused problems trying to get the rivets out. While this went on, we noticed that the rivets for the whole window regulator have failed. So I returned the motor and got the whole regulator with motor instead. Why did the regulator rivets fail? BTW, 2000 s-10 blazer four door.
atvwarrior
Jul 1, 2013 05:14 PM
mitchiemitch422
Oct 2, 2011 11:29 PM
argue_with_a_tree
Feb 28, 2011 05:57 AM
Riktar
Dec 21, 2010 11:20 AM
chevyfan22
Mar 7, 2010 06:27 PM
