Problems starting 01 blazer LT
Old Dec 18, 2014 | 01:51 PM
Blazer3337's Avatar
Blazer3337 is on a distinguished road
Default Problems starting 01 blazer LT
I just got a new fuel pump, plugs and wires and it's running like a champ. Well today I go out to start the blazer and... Nothing. Just the electrics come on. It won't even crank. My battery is good and I have no other electrical problems. At this point I have no idea what it could be. Is it possible the pump was put in wrong? The mechanic I had do it was trusted and a reputable shop. With the new plugs and wires and the new fuel pump I am at a loss as to why it won't start or even crank. Any suggestions?
Old Dec 27, 2014 | 08:16 PM
baja1000's Avatar
baja1000 is on a distinguished road
If it's not cranking then you have a problem with starter or your not getting power to the starter. Check fuses and wires good luck.
cgrett
Nov 15, 2010 09:08 PM
Bootyjones
Feb 9, 2010 06:09 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
