Quad beam on 98+
Hi, I am trying to do the quad beam on my 98 blazer but have searched and can only find information on 95-97. I have the relay and everything I need. Is the ground switched or is the power? My buddy hooked it up like his 1998 1500 pickup but it didn't work on mine. Would this be wired the same as say a NBS chevrolet? Sorry if this is beating a dead horse.
Thanks in advance. |
Bump, Need help asap.
Originally Posted by boost3d
(Post 307979)
And BTW, the first two pictures in the link posted above are of a 2000 Bravada. |
Ugh, don't we have another thread that was started JUST 2 days ago with the same topic? You guys need to put that search button to use.
I used the search button, I've googled it maybe a dozen times. There isn't really a detailed thread. The brevada isn't a blazer so they're not the same colored wires. So... I guess I'll have to figure it out my self.
(Post 308229)
Currently I just have grounded out the yellow wire on the low beam on the drivers side headlight. Then when I turn my hi-beams on I get 4-high on drivers side and nothing on passenger side. But when I turn it back to dims my drivers side dim is normal, and the high beam light is dim. On the passenger side both lights are dim. I have tried multiple ways, including stock and it hasn't worked. Maybe I blew a fuse or relay?
Bravada isnt the same thing?! lol
Originally Posted by Ryanmatt135
(Post 308508)
