Quad Beam Mod.. Using Relays - Easy, Diagram Attached!
See attached photo.. i put together a diagram i use on all my installs.. Also in the diagram, how to switch polarity from (-) to + using a relay for those of you who have a (-) switched wire to activate high beams. (I assume should be most if not all of the blazers, s10s, jimmys, bravads, and sonomas) Hope this helps everyone! This is a great and safe way to wire it up if you plan on wiring in all hids!
cr8390
107
Jul 17, 2018 10:58 PM
blazedandconfused95
Oct 22, 2009 12:26 PM
cr8390
Feb 23, 2009 07:59 PM
NVANZEE
Dec 22, 2008 06:18 AM
