Quad beam question
Old Jan 2, 2012 | 08:30 PM
Blazer_LT's Avatar
Blazer_LT is on a distinguished road
Default Quad beam question
ok so i have a set of hid projectors on the way. i want to do the quad beam mod. but from all the posts i have read i will lose my auto drl and auto head lights.
is this correct?
if so then how would i keep my drl and automatic headlights.
i have a 2000 lt blazer.
thanks in advance for any ideas
also not sure if i posted in the right section. if so please let me know.
Old Jan 3, 2012 | 07:46 PM
Blazer_LT's Avatar
bummp
Old Jan 3, 2012 | 08:03 PM
warthogdriver's Avatar
Quadbeams
that should help you figure out what your options are.
as far as the ahl system...i disabled mine once i did the hid and quadmod...what happened is the ahl system would turn on the lights then when i started the truck it would screw up the hid system...i guess its the voltage flux they dont like....
i found there are ways around it like engaging the e-brake then release it...i figured if i am gonna do that i might as well disable the ahl and use the switch on the dash for the lights.
up to you i guess and what you want to do with it.
Old Jan 3, 2012 | 08:22 PM
Blazer_LT's Avatar
that makes sense. i will see what happens when i put mine on whether or not i will get rid of the ahl or not. thanks very much warthog. i have been searching like crazy
Old Jan 3, 2012 | 08:27 PM
not a problem...like alot of things...its knowing how to ask for what you want.
that works for google....promotions...and women
Old Jan 4, 2012 | 12:29 AM
Blazer_LT's Avatar
i had read that post before so i knew the way to do it. i was jjust trying to figure out why people disable the ahl when it is a nice feature if you are a person who will walk at night and then get in your car and forget to turn on head lights. i do it often also in the morning when i go to work. if those bad boys didnt turn on by themselves i would forget lol
Old Jan 4, 2012 | 11:36 AM
gojorg's Avatar
I don't disable the ahl because I'm used to put the parking brake on every time I park, I have hid's and noticed that there could be a problem when u start the truck and the ahl kicks in because my sister drove it one day and did not put the parking brake on but if you do use the parking brake the ahl won't activate until you release the parking brake and no problem turning on the hid's
Old Jan 4, 2012 | 12:07 PM
Rottidog's Avatar
This might help you...
Old Jan 4, 2012 | 12:11 PM
*snip*
Copied that to your photobucket account did ya. LOL
Here's the full res copy of the 2000 non-zr2 headlight wiring schematic I pulled together from 4 separate schematics & marked up a very long time ago (click on the thumbnail) in case there are parts you can't read:
Here's a more condensed version of the above (different source) that prints out well on a single 8.5x11 sheet, but doesn't have the logic table included in the schematic above:
Old Jan 4, 2012 | 12:13 PM
Rottidog's Avatar
lol yup then added it as a thumbnail instead. It opens up bigger & clearer than inserting a huge picture that takes up too much space.
